makeWebRequest returns responseCode == 0 (possibly SSL handshake problem?)
Hi, My app downloads data off a web server using makeWebRequest. This has worked fine but when I recently added support for Edge devices, I noticed that with some of the Edge devices (1030, 530, 830), makewebrequest returns no data and responseCode == 0 when tested in the simulator (I cannot test with real devices).
I looked at the HTTP log in the simulator and I see some encoded messages going back and forth between the device and the server, it looks like an SSL handshake ( I can read some information about the SSL certificate, etc) but no HTTP (POST) request i sent and consequently no data is sent back. When I test with other devices, I see the same SSL handshake sequence, but followed by the HTTP post request and the correct HTTP response data.
This issue is only with some of the Edge devices (1030, 830, 530), other Edge devices work fine.
Im using target SDK v. 3.1.x
I have disabled "Use Device HTTPS requirements" in the sim. Im out of ideas. Thanks in advance
best regards
Fredrik
