Hi,
When it will be possible to develop EDGE datafields / app with SDK 3.2.x.
Last firnware 11.00 support SDK 3.2. So what we need to do?
Thanks in advance,
Hi,
Thanks in advance,
Changes like this happen when you update the devices using the SDK manager. It doesn't look like the edge devices have been updated for 3.2 functionality as of yet. You can use the 3.2.3 SDK to build for the edge device, just not test any of the new 3.2 functionality in the sim, only on a real device.
I don't understand the way Garmin handles this. In my opinion the developer should be able to test with 3.2 before it has been released on the physical devices. At this moment my Edge 1030 is 3.2 compatible but I can't use the new functionality in the simulator. I would like to read sport and sub sport for the current activity. It has been available for over 2 months now but I can't use it.
The problem there is if a dev starts using 3.2 functionality and publishes the app, but the device doesn't have 3.2 yet, that can cause crashes. The SDK update is always either at the same time or after the device gets the production FW.
I believe the edge devices (as well as a few others) should be updated now. You'll need to download new device configs using the SDK manager.
Yes they are. Thank you.
When I read the sport and subsport from my profiles on the Edge 1030 I see subsports that are not listed in https://developer.garmin.com/connect-iq/api-docs/Toybox/Activity.html
Examples are:
46 Gravel Cycling
48 Commuting
I can also choose these subsports in the Simulator.
What is the best way to report errors an d typos in the AOI documentation?
Post them in the bug report forum
