Tutorial for Linux (Connect IQ 3.2.3)
Can someone help me with setting up connect iq sdk + eclipse? Eclipse is not necessary, terminal scripts are fine as well as I don't need a lot of them and the eclipse plugin is very basic anyways.
It looks like the process is like following:
Additionally I did the eclipse SDK setup like described here: https://developer.garmin.com/connect-iq/sdk/
The first problem that comes up is that I can't start a SDK manager as I can't find one... Can someone help here?
PS:
I also found this link that contains the sdk manager https://developer.garmin.com/downloads/connect-iq/sdk-manager/connectiq-sdk-manager-linux.zip but this one does not start at all...
  • Sorry for being late to the party, but I might have found some solutions for the linux problem for the Fedora users.
    You have to check if you have all of those installed on your pc, typing them into the terminal inside the folder with sdkmanager file:
    sudo dnf install libjpeg-turbo
    sudo dnf install libjpeg-turbo-devel
    sudo dnf install @development-tools
    sudo dnf install webkit2gtk4.0 gtk3
    sudo dnf copr enable aflyhorse/libjpeg
    sudo dnf in libjpeg8
    ./sdkmanager
