Connect IQ 1.2.4 SDK Available!
Connect IQ SDK version 1.2.4 is now available for download!
You can get it one of two ways:
  • Use the Connect IQ SDK Manager in Eclipse, by clicking the Connect IQ menu, selecting Open SDK Manager, and then clicking the Download button for Connect IQ SDK v1.2.4 released February 2, 2016.
  • Download directly from our developer site at http://developer.garmin.com/connect-iq/sdk/
General Changes:
  • Address custom font rendering problems on the 920XT.
  • Fix case where it was possible to upload Edge 1000 / 520 widget or watch-app.
  • Fix memory leak when creating / destroying a device context (dc).
  • Reduce memory consumption when creating large numbers of objects.
Simulator Changes:
  • Adjust System.getDeviceSettings() to take into account landscape mode in the Simulator.
  • Fix occurrences of “Too Many Objects” error when receiving JSON requests in the Simulator. Very large JSON requests may still produce this error, although valid in this instance to better emulate devices.
  • Better alignment of reported memory estimates between OS X and Windows.
  • Devices have a limit to the number of objects they can allocate. A “Too Many Objects” error is issued when this limit is reached; the number has been increased to better reflect device capability.
Known Issues:
  • If an Exception is thrown from a catch block, the finally block of the current try/catch/finally will not be executed.
  • The compiler is processing custom fonts in a way that allows for more data to be specified, but hand-made font files may display slightly different.
  • This is great. The new version of the SDK has managed to reduce the previous 1.2.3 SDK memory size/consumption.
    However, compared to 1.2.1 it is still eating up an additional 0.5kb of memory.
  • Will test rendering issues on the 920 but the comment about hand made fonts leaves me wondering. By hand made do you mean made with BMPFONT?
    It refers to fonts that are manually tweaked by hand after it was created with BMFont.
    You have to be careful not to modify just anything exported by BMFont unless you understand what you are doing.
    For instance, if you resize the png by cropping it, you have to make sure your values in the fnt file matches the new dimensions.
    Other properties in fnt could have a relationship, so when changing something, there might be another property that has to be kept in sync.
    There is a tighter relationship between some properties and their values.
    The ConnectIQ compiler uses more of them than in the past.
    I have already confirmed that the font rendering issue on the 920xt is solved by this release :)
  • Just to follow up additionally on the font issues, we're looking at ways to better address custom font management in the future. There are a few different ways we could approach it, so it's going to take some time to investigate and find what works best with the fewest compromises. We'll do our best to minimize font problems in the meantime, of course, but I'm optimistic that fonts management will function much better in future versions of the SDK.
    When it is possible support Cycling dynamics and DI2 values for data fields
    Hi,
    I want to know when it is possible the SDK support Vector Cycling Dynamics data including power balance, touque efficiency, Pedding smooth, and Power Phase, Power Peak Phase, Center pedalling offset.
    Also, the DI2 infomation such as Gears ratios, etc.
    Additionally, when Garmin edge 1000 can use customized Layouts for data fields?
    Recently the internal layouts set the 5 will be like this:
    ._________.
    |_________|
    |_________|
    |_________|
    |_________|
    |_________|
    Is that possible to use 5 layouts like:
    ._________.
    |_________|
    |____|____|
    |____|____|
    Do we still have to manually change the xadvance to match the width?
  • The way I see it is that the hard work of fixing your fonts should already have been done.
    You've already fixed the fonts in order to compile with the previous SDK, so in theory it should not be an issue going forward.
    If you want to make new fonts, just check with that font if you need to do the xadvance trick.
    I suppose if it is still a problem, the folks here will take another look at it.
    At the moment all my fonts are good for compilation. However, In future when creating new fonts, I will be very careful not to change too many things manually.
    Obviously if a BMFont exported font, with no manual changes, won't play ball with the compiler, report it together with a zip of your *.fnt and *.png files.
  • I do need to do my fonts again as need to add Greek and Cyrilic chars.
  • Hi,
    ._________.
    |_________|
    |_________|
    |_________|
    |_________|
    |_________|
    ._________.
    |_________|
    |____|____|
    |____|____|
    We have tasks already on our list that will include adding cycling data to activity info, so that's planned. I don't know exactly when it will be available, but I think it's safe to say some of these items will be sometime this year.
    Data field layouts are controlled by the product, so that's really a question the product team would need to answer. I don't know whether they have plans to allow more layout customization or not. However, you could design a Connect IQ data field that mimics two separate fields if you wanted, like in your lower example.
