Hi -
I have a very simple watchface that I have successfully been building for myself. Recently when I try and use a Run Configuration, Eclipse gets stuck on about 45% of the way through the build and reports "Launching Delegate...". It fails because of timeout. I have removed the 60 second timeout limitation and it just sits there forever.
I have updated to the latest SDK and tried using old ones. I've removed eclipse and reinstalled, changed workspaces, created new empty watchfaces to test with - all with the same results.
ANY help would be appreciated at this point - I'm unable to use the simulator or the "build for device" wizard to update my watchface.
Thank you!
