Since SDK 3.2.x Symbol Not Found Error @ last line of code
I'm getting a serious 'Symbol Not Found Error' reported by ERA always at the last line of my app code. This bug is introduced since the first version of SDK 3.2.x.
Even when i simply move a code segment to the bottom (e.g. a function) the 'Symbol Not Found Error' points always at the last line of the code.
Do you get similar errors and what can I do to fix this issue.
Hint: The app runs perfectly in the simulator and on fenix 5X and 6X devices although the devices log the strange error.
Error: Symbol Not Found Error
Details: "Could not find symbol '00800003'"
Part-Number: 006-B3291-00
Firmware-Version: '12.10'
ConnectIQ-Version: 3.2.3
Stack:
  - pc: 0x30003aa9
  • The crash being reported on the last bit of your code is a known issue that we don't currently have a fix for. It can happen when the address of the crash is beyond the area of code that is described by the debug information for your code.
    As for the actual source of the problem, I can't really tell given the information provided. I think the easiest way forward would be to provide the name/appid of your app if it is in the app store, or a .PRG that we can use to reproduce the crash.
  • Here the link of the app store:
    https://apps.garmin.com/de-DE/apps/fc3f9b9f-add6-46cb-8e0b-9a2172a04c31
    Here the list of affected devices:
    Devices:
        fēnix® 6X Pro / 6X Sapphire / 6X Pro Solar / tactix® Delta Sapphire / Delta Solar / Delta Solar - Ballistics Edition / quatix® 6X / 6X Solar / 6X Dual Power: 11.10, 12.10
        fēnix® 6S / 6S Solar / 6S Dual Power: 11.10
        Forerunner® 945: 5.00
        Forerunner® 745: 3.00
        fēnix® 6 Pro / 6 Sapphire / 6 Pro Solar / 6 Pro Dual Power / quatix® 6: 11.10
        fēnix® 6 / 6 Solar / 6 Dual Power: 11.10
        vívoactive® 4: 5.10
        MARQâ„¢ Adventurer: 11.10
        MARQâ„¢ Athlete: 11.10
        MARQâ„¢ Aviator: 11.10
        First Avenger: 4.90
        Darth Vaderâ„¢: 4.90, 5.10
