CIQ 3.2 WatchFace setting menu. getSettingsView() directly to Menu2?
Hi,
I read a few times here on the forum that you can go directly to the Menu2 and don't go to an extra view where you must longpress the menu button. I tried to implement this in my watchface but I get a black screen and I don't get how you can put a Menu2 and InputDelegate in getSettingsView(), because it is asking for a View and a InputDelegate. What else do I need to change to make it work and show the menu directly? Is there a sample code that does work? Or can we make the Analog sample work without the AnalogSettingsView?
I tried a lot of things. Hopefully someone can help me. Thanks a lot!
Sample code:
class MyWatchFaceApp extends Application.AppBase {
    //default functions
    function getSettingsView() {
        return [new SettingsMenu2(), new SettingsBehaviorDelegate()];
class SettingsMenu2 extends WatchUi.Menu2 {
    function initialize() {
        Menu2.initialize({:title=>"Settings"});
class SettingsMenu2InputDelegate extends WatchUi.Menu2InputDelegate {
        Menu2InputDelegate.initialize();
    function onSelect(menuItem) {
        Application.getApp().setProperty("Sample",menuItem.isEnabled());
        WatchUi.requestUpdate();
    function onBack() {
        WatchUi.popView(WatchUi.SLIDE_DOWN);
    function onDone() {
class SettingsBehaviorDelegate extends WatchUi.BehaviorDelegate {
        BehaviorDelegate.initialize();
    function onMenu() {
        var menu = new SettingsMenu2();
        var boolean = Application.getApp().getProperty("Sample") ? true : false;
        menu.addItem(new WatchUi.ToggleMenuItem("Sample", null, 1, boolean, null));
        WatchUi.pushView( menu, new SettingsMenu2InputDelegate(), WatchUi.SLIDE_IMMEDIATE);
Top Replies
All Replies
