Help! Some question about datafield layout
I want to develop a datafield similar to Bontrager Light Control, but I don't know how its layout was developed.
I have been researching for a few days, but this datafield can't push or pop view, can't new WatchUi.View in getInitialView(), can't use Button, and WatchUi.BehaviorDelegate just respond onTap event. So I want to know how to develop can be like Bontrager Light Control.
First Q : Why the first page can change a new page when the light is connected ?
Second Q : Is the layout of the second picture a datafield?
Third Q : How create button if the layout of the second picture is datafield ?
Fourth Q : How to respond to click events if the layout of the second picture is datafield ?
Thank you for your help.
  • With a complex DF, you don't need to use layouts, you can use direct DC calls.  In the case of the buttons, you can use dc.fillRectangle(x, y, width, height)
    and then in onTap(), you look at the screen coordinates of the tap and see if it's within a button or which one
    Like this.  Screens.button is an array that defoiines where the button was drawn on the screen.
    	function onTap(evt) {
    		var coord=evt.getCoordinates();
    	    if(coord[0]>=Screens.button[0] && coord[0]<=(Screens.button[0]+Screens.button[2])) {
    			if(coord[1]>=Screens.button[1] && coord[1]<=(Screens.button[1]+Screens.button[3])) {
    				handleButton();
    0 Former Member in reply to jim_m_58
    Thank you so much for your reply, I will try
  • I have not looked at the source code for that app, but I'm 99% sure I know how it works. All of this can be done in a ConnectIQ data field, with or without a layout.
    I don't fully understand the question.
    With a data field, you essentially get one view class (the one that inherits from DataField or SimpleDataField). The system will call onUpdate() on this data field every second.
    You can use this to your advantage by changing what is displayed based on context. Your DataField just needs to keep track of the current state, and load the appropriate layout or execute the appropriate display code based on that state.
    Yes. Using the technique mentioned above.
    If you use layouts, you configure the view to use a layout with a button element defined in it. If you don't use layouts, you draw a rounded rectangle where the button is supposed to be.
    If you use a layout, the button element has a behavior attribute that is the name of the function of your delegate that should be called when the button is pressed (doc). If you don't use a layout, you can still use the Button class, or you could do as  has suggested and use an onTap handler to detect the tap yourself.
