Running sample application just gives "null" in Eclipse console
Hi!
I tried to run the sample app ConfirmationDialog that comes with the SDK from Eclipse using "Run As Connect IQ App", but the only output I get in the console is "null". I've started the simulator prior to running the app, but it doesn't show some device. It seems to compile fine in eclipse and running it in the simulator by using monkeydo on the command line also works. However, I'd prefer starting/debugging the app right from Eclipse. Any suggestions what the reason for the "null" console output could be or how I could debug it further? My eclipse version is 2020-06 (4.16.0), skd version is "connectiq-sdk-lin-3.2.2-2020-08-28-a50584d55".
best regards,
Christian
Top Replies
All Replies
