Sensor Permission Erroneously Available for Watch Face?
ConnectIQ SDK : 1.2.3
Eclipse : Mars.1 Release (4.5.1)
I am under the impression that this is not allowed due to battery conservation efforts (see attached image).
I got all excited that I could add altitude data to my watch face but when I try to implement the class Toybox.Sensor as such (having added the appropriate permission to my manifest):
using Toybox.Sensor as Sens;
class MyWatchFace extends Ui.WatchFace {
function onUpdate(dc) {
snsr = Sens.getInfo();
alt = snsr.altitude;
The compiler throws a 'Permission Required / Failed invoking <symbol>' error which is to be expected, I guess. If this is not allowed then why is the option available?
  • That was fixed in SDK 1.2.3:
    "General Changes:
    Prevent sensor permissions from being selectable for watch-faces in Eclipse."
    from https://forums.garmin.com/showthread.php?341675-Connect-IQ-1-2-3-SDK-Available!&p=794435#post794435
    Are you sure you're not still running 1.2.2? It's grayed out for me on 1.2.3.
    If you checked it with 1.2.2, there might not be a way to remove it in 1.2.3, so you may have to edit the manifest file directly to remove it.
    Hi Jim -
    From Eclipse->Help->Installation Details:
  • This permission is defined in your current SDK tree in the "bin\projectInfo.xml" Here's what's in mine for 1.2.3 for watchfaces"
    <permissionMap appType="watchface">
    <permissions>
    <permission id="Steps" />
    <permission id="UserProfile" />
    </permissions>
    </permissionMap>
    Version 1.2.2 also had sensors....
    <permissions>
    <permission id="Sensor" />
    </permissions>
    </permissionMap>
    In Eclipse, in the window menu, preferences, Connect IQ, what is the path you have for the SDK? The picture you posted are for the plug-ins, but not the SDK itself. For that you can download the SDK, or use the "SDK manager" in the "Connect IQ" menu.
