Hi, how can I prevent the second hand from stopping me when I put the Fénix5 into mode: low power?
Thank You
Thank You
You need to implement 1Hz watchface (onPartialUpdate) support. I can't seem to find the documentation right now, but the Analog sample app is a pretty good resource.
If you're using the 3.2.1 or later SDK, you need to import the project from one of the SDK folders in %APPDATA%\Garmin\ConnectIQ\Sdks and take a peek around.
Where would one find this Analog sample app?
It's in the SDK samples directory. In eclipse. go to ConnectIQ>samples. On windows with 3.2.x or greater, SDKs are in \users\(you)\appdata\roaming\garmin\ConnectIQ\sdks.
Also, see this thread:
https://forums.garmin.com/developer/connect-iq/f/discussion/5156/1hz-watch-faces---q-a/
