Hi guys,
I am trying to figure out how to rotate text labels. Any ideas on how this may be done?
Thanks.
Hi guys,
Thanks.
It is not possible to rotate a text label using the API. There are several tricks that you can use to get the effect that you want, but all of them involve generating a font with rotated characters and then placing them in appropriate positions.
Thanks Travis.
Darn, that will be tricky as I am trying to put text around a circle.
Does anyone know if this is still a limitation? I'd like to have numbers vertically
Nothing has changed with this.
Is this what you're looking for?
I am generating a set of png files in PHP which I am able to scale for different screen sizes and for each of the 64 compass points.
I plan to install them as sets of resources for each screen size (using Jungles) and at run-time display the one that represents the direction of travel. OK. it will be inaccurate by a max of ~3° (5.6125/2).
PM me if you're interested in collaborating.
I guess there is the difference between "possible" and "sensible". ;) My best guess is that at least some of the developers here would accuse me of heading further to the wrong end of that line...
But I did Roundular | Garmin Connect IQ as a proof of concept using points manipulated via matrix.
