Up-to-date Simulator known issues sticky post request.
Since it's not realistic to expect that a developer has all of his application supported devices at hand to test, at some point we have to rely on the simulator.
Personally I bumped into several issues where things worked in the simulator, and not in the real device.
Do you know if there is a sticky post with known issues/limitations for the simulator?
Thanks!
  • With the bug reports, there's a couple things you can do to find this.
    The default sort order is "by highest score", but you can set it to "by date" and see things based on when they were reported.
    Another is to use "search" in the bug reports and look for "fenix" for example.
    The problem with a sticky is maintaining it, and even with the bug reports, the status doesn't always get updated right away.
