how can i locate function the same way you locate a text?
example
i locate this
function drawRec(dc) {
dc.setColor(aColor, Gfx.COLOR_TRANSPARENT);
dc.fillRectangle(0, 100, 120, 4);
function onLayout(dc) {
View.setLayout(Rez.Layouts.MainLayout(dc));
var valueView = View.findDrawableById("value");
valueView.locY = valueView.locY + 14;
function onUpdate(dc) {
value.setText(lastPower);
or on complex template how do i send a rectangle back to the text
using Toybox.WatchUi;
using Toybox.Graphics;
class ${viewClassName} extends WatchUi.DataField {
hidden var mValue;
function initialize() {
DataField.initialize();
mValue = 0.0f;
// Set your layout here. Anytime the size of obscurity of
// the draw context is changed this will be called.
var obscurityFlags = DataField.getObscurityFlags();
// Top left quadrant so we'll use the top left layout
if (obscurityFlags == (OBSCURE_TOP | OBSCURE_LEFT)) {
View.setLayout(Rez.Layouts.TopLeftLayout(dc));
// Top right quadrant so we'll use the top right layout
} else if (obscurityFlags == (OBSCURE_TOP | OBSCURE_RIGHT)) {
View.setLayout(Rez.Layouts.TopRightLayout(dc));
// Bottom left quadrant so we'll use the bottom left layout
} else if (obscurityFlags == (OBSCURE_BOTTOM | OBSCURE_LEFT)) {
View.setLayout(Rez.Layouts.BottomLeftLayout(dc));
// Bottom right quadrant so we'll use the bottom right layout
} else if (obscurityFlags == (OBSCURE_BOTTOM | OBSCURE_RIGHT)) {
View.setLayout(Rez.Layouts.BottomRightLayout(dc));
// Use the generic, centered layout
} else {
var labelView = View.findDrawableById("label");
labelView.locY = labelView.locY - 16;
valueView.locY = valueView.locY + 7;
View.findDrawableById("label").setText(Rez.Strings.label);
return true;
// The given info object contains all the current workout information.
// Calculate a value and save it locally in this method.
// Note that compute() and onUpdate() are asynchronous, and there is no
// guarantee that compute() will be called before onUpdate().
function compute(info) {
// See Activity.Info in the documentation for available information.
if(info has :currentHeartRate){
if(info.currentHeartRate != null){
mValue = info.currentHeartRate;
} else {
mValue = 0.0f;
// Display the value you computed here. This will be called
// once a second when the data field is visible.
// Set the background color
View.findDrawableById("Background").setColor(getBackgroundColor());
// Set the foreground color and value
var value = View.findDrawableById("value");
if (getBackgroundColor() == Graphics.COLOR_BLACK) {
value.setColor(Graphics.COLOR_WHITE);
} else {
value.setColor(Graphics.COLOR_BLACK);
value.setText(mValue.format("%.2f"));
// Call parent's onUpdate(dc) to redraw the layout
View.onUpdate(dc);
