I've never seen this issue before. Even if the latest SDK doesn't have an Eclipse Plugin update. Did the URL change?
DaveBrillhart- I don't see any error in the screenshot above.
If you've added a repository named Connect IQ (as shown above) you should be able to select it from the Work With dropdown and the list box should populate with items you can install.
I've verified that the URL you need to use is the one you're showing above. I was able to use it to get listings for Connect IQ IDE and Connect IQ SDK Manager versions 3.1.7.
Hi Travis,
Maybe this was the behavior prior, but it seems to act differently like something isn't working correctly. I do see that 3.1.7 is the version I have installed. But when I check to see if a new version was released with SDK 3.1.9, here is what happens.
Work With: Connect IQ
ADD -> Locaton: developer.garmin.com/.../eclipse
After I hit "ADD" I get "no site selected" and Work With reverts to null, like it didn't accept the URL and doesn't tell me I have the latest or that no new update is available.
The last plugin is 3.1.7. There wasn't a new plugin for 3.1.8 or 3.1.9. (a new SDK doesn't always mean a new plugin)
Could that be involved?
That must be it... But that happens often (no plugin with an SDK), and I've just never seen the Eclipse response act like the URL was bad ("no site selected").
