Simulating FitnessEquipment and FitnessEquipmentSettings
Hi,
I have a user request to read and refer to AntPlus.TargetPowerSettings.targetPower in one of my DataField dials. I just need to know what the number is, so I don't need to be listening for changes or otherwise adding complexity. I just need to read it, once, during setup.
If I'm, correct, I can do this simply like the below:
if(AntPlus has :FitnessEquipment) {
	Toybox.System.println("Has FitnessEquipment");
	var fe = new AntPlus.FitnessEquipment(null);
	var fes = fe.getTargetPowerSettings();
	if(fes != null && 	fes.targetPowerSupported) {
		tPower = fes.targetPower;
		Toybox.System.println("FE has target power support to get "+tPower);
} else {
	tPower = null;
However, as ever, I do not have either an Edge device, a power meter, or fitness equipment to test this on live.
Is there any way to simulate or otherwise verify this?
Thanks,
G
ETA: I also need to verify whether or not I need to manage "setTrainerMode()" or if I can just read "getTrainerMode()" as the docs say that there will be no TargetPowerSettings unless the trainer mode is in "target power" mode.
