Sensor.Info to access VivoActive temperature
Is it possibile to read VivoActive temperature ? When in debug mode VivoActive show a temperature by internal sensor I suppose.
  • Is it possibile to read VivoActive temperature ? When in debug mode VivoActive show a temperature by internal sensor I suppose.
    The vivoactive doesn't have an internal temperature sensor. For an app to get the temperature on a va, the va needs to be paired with a Tempe sensor.
    In the simulator, you can get temperature data by going to simulation>fit data>simulate data
  • Vivoactive diagnostic
    In diagnostic mode .... I think pushing start after having connected to usb there is a lot of test you can do and there is also a temperature reading I used this summer at sea ....
