I am having issues starting the simulator. When I try to start it from within Eclipse it appears to try and start it but you get no feedback and when you run the watchface it can't find the simulator. When I try to start the simulator from command prompt it can't find a shared object:
~/garmin_sdk/connectiq-sdk-lin-3.1.8-2020-05-01-05516d846/bin$ sudo ./simulator
[sudo] password for <user>:
./simulator: error while loading shared libraries: libpng12.so.0: cannot open shared object file: No such file or directory
Will Garmin support Ubuntu 20.04? If not, can you provide users like myself with an alternative way to develop?
The following are the particulars of my system:
Linux PC running Ubuntu 20.04 LTS: Linux lx 5.4.0-31-generic #35-Ubuntu SMP Thu May 7 20:20:34 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
Eclipse IDE for Java Developers
Version: 2020-03 (4.15.0)
Build id: 20200313-1211
OS: Linux, v.5.4.0-31-generic, x86_64 / gtk 3.24.18, WebKit 2.28.2
Java version: 11.0.7
java 11.0.7 2020-04-14 LTS
Java(TM) SE Runtime Environment 18.9 (build 11.0.7+8-LTS)
Java HotSpot(TM) 64-Bit Server VM 18.9 (build 11.0.7+8-LTS, mixed mode)
Thanks
