Is it possible to run multiple instances of the simulator?
Hey guys!
I'm just preparing another update for my app, so a lot of testing has to be done. I was just wondering if it is possible to start multiple instances of the simulator, each showing a different watch. With 40 devices to support and check I would love to break down 40 1-hour long tests into 8 or even 4 1-hour long tests by running 5 or 10 instances of the simulator in parallel.
I haven't found a setting in Eclipse to overwrite the default behavior of allowing only one instance to run at the same time. Are there command line arguments I can pass to the simulator to circumvent this limitation?
