Is it allowed to publish watchfaces etc. on github? I've found some repos, so I guess the answer is "yes", but I want an "official" answer about this topic.
There is a license file in the SDK (resources/readme/licenses/CIQ-LICENSE-AGREEMENT.html). You can find it more easily by opening up the README.html in the root of the SDK.
The gist is that Garmin owns…
I should insert the disclaimer that I'm not a lawyer, and for legal advice you may want to consult a lawyer... yada yada yada.
People have used github since the early days of CIQ, including Garmin itself. https://github.com/garmin/connectiq-apps
Someone like Brandon.ConnectIQ can give you the official answer, but he and I have talked…
Someone like Brandon.ConnectIQ can give you the official answer, but he and I have talked about putting some of my samples on on github in the past. (he was asking me if I wanted to do it)
The gist is that Garmin owns the SDK, the Developer Program, Program Materials, and the website. You are licensed to use them. You own your application, and license Garmin to use and distribute it.
Your application source code is your IP, and you can do whatever you want with it, provided it doesn't violate those terms (or terms of any other agreement you may enter into).
Thank you Jim and Travis for your detailed answers!
