It appears that Fenix 5 device, which features a "Bluetooth Smart" interface, does not make available the BluetoothLowEnergy API. Is this expected?
Yes it's expected. While CIQ 3.1 supports BLE, not all devices with CIQ 3.1 support it.
See this post: https://forums.garmin.com/developer/connect-iq/b/news-announcements/posts/connect-iq-3-1-connects-you-to-the-world
There are newer devices that support it that aren't on the list.
You can also check https://developer.garmin.com/connect-iq/compatible-devices/, and click on the blue circle with the "I" and look for
You'll see it on the f5+ and not the f5 for example
Hi, I hit the same problem on some devices, most notably on a brand new Venu SQ. The Music version of it supports BluetoothLowEnergy API, but standard doesn't! Why would a brand new device not support it?!
Also, there is another problem with SDK. When I select Permission BluetoothLowEnergy in manifest, it disables most Build Targets that supposedly not support the BLE API. However, Fenix 5 and Venu SQ are still available and let you build an app for them. Is it an SDK bug?
Thanks!
The Venu SQ is a low end device, so I'm guessing that the non music version just doesn't have the HW to support CIQ BLE.
As far as the permission, I fon't think it disabled targets that don't support BLE. Maybe just targets that don't support CIQ 3.1 at all. I've never noticed it, as I just set targets that I know support BLE.
By using something like Jungles or "has", you can write apps that will use BLE if it's available, but not required.
Here's my BleScan app in the sim for a non music Venu SQ and a Venu Sq Music showing how an app can make the determination.
For this app, stating that when it's run on a non supported device reduces requests to add a device that's not supported.
Thanks! I guess it makes more sense now - 3.1 with optional BLE support.
Core functionality of the app I developed (https://apps.garmin.com/en-NL/apps/53d9c500-614e-4e3a-88b6-9f65bc6a144a) depends on BLE, so I don't want it to even be available on devices that don't support BLE. It is a real bummer about Venu SQ - no BLE for a brand new device. The watch talks to a phone over BLE, so I can't imagine any extra hardware that it misses. And SDK doesn't make it easy to select compatible devices, I have to try every single one in a simulator...
By the way, I used your BT app sample - it is the only thing that makes sense on how to use BLE API. Thank you very much for posting it Jim!
