Hi all!
I am working on a watch face. After I receive information through WebRequest, depending on the response, I save the property using the setProperty method.
function onBackgroundData(data) {
Sys.println(data);
for (var i = 0; i < data.size(); i++){
if (data[i] != null){
if (data[i].hashCode() == "ERROR".hashCode()){
App.getApp().setProperty("testVar", "notOkay");
else if (data[i].hashCode() == "DONE".hashCode()){
App.getApp().setProperty("testVar", "okay");
Ui.requestUpdate();
This is what the properties.xml document looks like
<properties>
<property id="testVar" type="string"></property>
</properties>
While the dial is running, everything works. The string is saved and works correctly. However, if I exit the application and start it again, the data disappears.
getProperty returns what is specified by default in properties.xml
I’ve been racking my brains for three days looking for a solution to this problem. How do I save a value so that it works even after restarting the application?
