Communication issues
I am doing a web request for tide info. Code works fine, API key works fine.
Request comes out as success. (200). I trigger it every 3 hours, to conserve battery.
I then put the watchface in my watch to test it for longer periods, and after a while, it stops communicating successfully. I get error code -104
I think I also found a workaround. I just applied a different watch face, then reapplied mine, and it works again.
My assumption is that the issue is between the watch and the phone (iPhone). After w while the BT connection becomes flaky. When the watch starts the request, the phone does not go through with it, and I get an error code in return. Is this correct? If so, how do I solve it?
I have been trying to post logs but the forum is not allowing me to.
