When I build a clock without barrels, it just builds in the CLI. When I build it with a barrel, it fails; while it does just build & run when I build it within Eclipse. It also runs my barrel code, so all should be fine.
I'm getting this error:
com.garmin.connectiq.common.manifest.ManifestException: [102] The Monkey Barrel dependency MyBarrel (version 0.0.0) could not be resolved. Please make sure the barrel path was linked to within the main application's jungle file. at com.garmin.monkeybrains.ProjectBuilder.createBarrelContexts(ProjectBuilder.java:426) at com.garmin.monkeybrains.Monkeybrains.runPRGCompiler(Monkeybrains.java:1234) at com.garmin.monkeybrains.Monkeybrains.compileApplication(Monkeybrains.java:1024) at com.garmin.monkeybrains.Monkeybrains.run(Monkeybrains.java:2317) at com.garmin.monkeybrains.Monkeybrains.simpleMain(Monkeybrains.java:254) at com.garmin.monkeybrains.Monkeybrains.simpleMain(Monkeybrains.java:236) at com.garmin.monkeybrains.Monkeybrains.main(Monkeybrains.java:283)
I guess I'm missing something in the jungle file, but I have no clue what I should add. Can't find anything in the docs about it. Anyone that knows what I'm doing wrong here?
