Hello!
I'm working in a analog watch face, in which there is a filled circle at the end of the hour, minute and second hands. The code was working well, until I tried to condense it and write a function to set the hand coordinates (like the analog example, provided in the SDK). Then I will only get a "Error: Not Enough Arguments Error" console response.
This is the code, working as it should:
targetDc.fillCircle( center[0] + (center[0] - 50) * Math.cos(hourHandAngle), center[1] + (center[1] - 50) * Math.sin(hourHandAngle), 7 );
And there goes the function, arguments returned of it, and the console error log:
function handAttributes(center, distance, angle, radius) { var attrib = new [3]; attrib = [ center[0] + (center[0] - distance) * Math.cos(angle), center[1] + (center[1] - distance) * Math.sin(angle), radius]; return attrib; } function onUpdate(dc) { var width = targetDc.getWidth(); var height = targetDc.getHeight(); var clockTime = System.getClockTime(); var center = [width/2, height/2]; System.println(handAttributes(center, 50, hourHandAngle, 7)); targetDc.fillCircle(handAttributes(center, 50, hourHandAngle, 7) ); }
[130.000000, 50.000000, 7] <--- It seems the function is working fine, returning an array with 3 values in it.
Details: Failed invoking <symbol>
I am an absolute newbie in coding in general, and I'm probably missing something silly here, but can't figure it out! I'm using the latest SDK, and using mostly the Vivoactive 3 music as a simulator. Any suggestions?
