I have a barrel defined called Commons. Inside that barrel is a strings.xml resource. This is an excerpt from that XML:
<string id="common_on">On</string>
<string id="common_off">Off</string>
<string id="common_yes">Yes</string>
<string id="common_no">No</string>
<string id="settings_menu_choose_date">Choose Date</string>
<string id="settings_menu_about">About</string>
When I use this from code it works as expected: (Rez.Strings.common_on)
However when I try to use this from a menu XML something strange happens:
<menu-item id="about" label="@Commons.Strings.settings_menu_about"/>
This is the message that I get from the compiler:
BUILD: ERROR: An undefined resource reference was detected during resource processing: @CommonsStrings.settings_menu_about.
Notice that the dot between Commons and Strings has been deleted. It seems that there is a bug somewhere where that dot is stripped out and therefore the resource cannot be found.
Any ideas?
