Hi, I am working on a watch face that uses a layout that includes a text field and a bitmap:
<layout id="WatchFace"> <label id="textfield" x="center" y="center" font="Graphics.FONT_NUMBER_MEDIUM" justification="Graphics.TEXT_JUSTIFY_RIGHT" color="Graphics.COLOR_WHITE" /> <bitmap id="img" x="10 + (dc.getWidth() / 2)" y="(dc.getHeight() / 6) - 5" filename="myImage.png" /> </layout>
I would like to be able to change the bitmap reference in runtime and have tried to call setBitmap() but not sure how to reference the new bitmap file. I have all my bitmap files in the same folder as the layout.xml file, and have tried the following in onUpdate():
var bmp = View.findDrawableById("img");
bmp.setBitmap("anotherImage.png");
but then I get the following exception:
Error: Unhandled Exception
Exception: UnexpectedTypeException: Expected Number/Float/Boolean/Long/Double, given String
Stack:
- setBitmap() at T:\mbsimulator\submodules\technology\monkeybrains\virtual-machine\api\WatchUi.mb:4222 0x30003acc
- onUpdate() at C:\Users\fredrik\eclipse-workspace\NSFace\source\NSFaceView.mc:52 0x100004b6
I did also try to define all the bitmaps in drawables.xml:
<drawables> <bitmap id="myImage" filename="myImage.png" /> <bitmap id="anotherImage" filename="anotherImage.png" /> </drawables>
and tried this in onUpdate():
var bmp = View.findDrawableById("img"); bmp.setBitmap(Toybox.WatchUi.loadResource(Rez.Drawables.anotherImage));
I have obviously not understood how to use setBitmap(), or do I need to ditch layouts and use dc.draws instead? I kind of like the layout approach so was hoping I could use it. Im compiling this for one watch type only and the bitmaps will be updated once every 5 mins at most.
