makeWebRequest returns -400 responseCode in simulator
I've created a widget, and making a webRequest in the simulator is always giving me a -400 responseCode.
Please help! My code is below. I have <iq:permissions><iq:uses-permission id="Communications"/></iq:permissions> in the manifest...
class MyMenuInputDelegate extends WatchUi.MenuInputDelegate {
    function initialize() {
        MenuInputDelegate.initialize();
    function onMenuItem(item) {
        if (item == :one) {
            System.println("making req");
            makeRequest();
        } else if (item == :two) {
            System.println("Item 2");
       // set up the response callback function
   function onReceive(responseCode, data) {
       if (responseCode == 200) {
           System.println("Request Successful");                   // print success
           setBehaviorString("Request Successful");
       else {
           System.println("Response: " + responseCode);            // print response code
           System.println(data);
           setBehaviorString("Request failed: " + responseCode);
   function makeRequest() {
       var url = "https://helloacm.com/api/random";                         // set the url
       var params = {                                              // set the parameters
              "n" => "128"
       var options = {                                             // set the options
           :method => Communications.HTTP_REQUEST_METHOD_GET,      // set HTTP method
//           :headers => {                                           // set headers
//                   "Content-Type" => Communications.REQUEST_CONTENT_TYPE_URL_ENCODED},
//        // set response type
//           :responseType => Communications.HTTP_RESPONSE_CONTENT_TYPE_URL_ENCODED
       var responseCallback = method(:onReceive);                  // set responseCallback to
        // onReceive() method
       // Make the Communications.makeWebRequest() call
       Communications.makeWebRequest(url, params, options, method(:onReceive));
class widget1Delegate extends WatchUi.BehaviorDelegate {
    function onSelect() {
        onMenu();
        return false;
    function onMenu() {
        var menu = new WatchUi.Menu();
        var delegate;
        menu.setTitle("My Menu");
        menu.addItem("Item One", :one);
        menu.addItem("Item Two", :two);
        delegate = new MyMenuInputDelegate(); // a WatchUi.MenuInputDelegate
        WatchUi.pushView(menu, delegate, WatchUi.SLIDE_IMMEDIATE);
        return true;
