Has anyone had problems with background task not exiting correctly. The following test application works fine in the simulator but on my Fenix 5 the onBackgroundData function is not called.The strange part is that the function is called sometimes so it has to be something in my code.
using Toybox.Application;
using Toybox.WatchUi as Ui;
using Toybox.Time.Gregorian as Gregorian;
using Toybox.System as Sys;
var bkgAllowed = false;
class BkgTestApp extends Application.AppBase {
var dateTimeString;
var today;
function initialize() {
AppBase.initialize();
bkgAllowed = (Toybox.System has :ServiceDelegate and Toybox has :Background);
// onStart() is called on application start up
function onStart(state) {
function onStop(state) {
function getInitialView() {
if (bkgAllowed) {
Toybox.Background.registerForTemporalEvent(new Toybox.Time.Duration(5 * 60));
return [ new BkgTestView() ];
(:background)
function onBackgroundData(response) {
Sys.println("App: resp: " + response);
if (response instanceof Array) {
if (response[1]) {
today = Gregorian.info(Time.now(), Time.FORMAT_MEDIUM);
dateTimeString = today.hour + ":" +
today.min.format("%02d") + " " +
today.day_of_week.toString().substring(0,3) + " " +
today.day + " " +
today.month + " " +
today.year.toString().substring(2,4);
Application.Storage.setValue("lastCharge", dateTimeString);
Sys.println("App: write charge: " + dateTimeString);
Ui.requestUpdate();
(:background)
function getServiceDelegate(){
return [new BkgTestBkg()];
using Toybox.Background;
(:background)
class BkgTestBkg extends Toybox.System.ServiceDelegate {
var response = [0.0, false];
Sys.ServiceDelegate.initialize();
function onTemporalEvent() {
response[0] = Sys.getSystemStats().battery;
if (Sys.getSystemStats() has :charging) {
response[1] = Sys.getSystemStats().charging;
} else {
response[1] = false;
Sys.println("bkg: charging: " + response[1] + " bat: " + response[0]);
Background.exit(response);
using Toybox.Application as App;
using Toybox.Graphics as Gfx;
class BkgTestView extends Ui.View {
var w2;
var h2;
var lastCharge = "";
View.initialize();
w2 = Sys.getDeviceSettings().screenWidth / 2;
h2 = Sys.getDeviceSettings().screenHeight / 2;
function onLayout(dc) {
setLayout(Rez.Layouts.MainLayout(dc));
function onShow() {
function onUpdate(dc) {
dc.setColor(Gfx.COLOR_BLACK, Gfx.COLOR_BLACK);
dc.clear();
dc.setColor(Gfx.COLOR_WHITE, Gfx.COLOR_TRANSPARENT);
if (bkgAllowed) {
lastCharge = App.Storage.getValue("lastCharge");
if (lastCharge != null and lastCharge.length() > 1) {
dc.drawText(w2, h2, Gfx.FONT_SYSTEM_XTINY, "Last charge:", Gfx.TEXT_JUSTIFY_CENTER | Gfx.TEXT_JUSTIFY_VCENTER);
dc.drawText(w2, h2 + Gfx.getFontHeight(Gfx.FONT_SYSTEM_XTINY)*1, Gfx.FONT_SYSTEM_XTINY, lastCharge, Gfx.TEXT_JUSTIFY_CENTER | Gfx.TEXT_JUSTIFY_VCENTER);
} else {
dc.drawText(w2, h2, Gfx.FONT_SYSTEM_XTINY, "no charge info found", Gfx.TEXT_JUSTIFY_CENTER | Gfx.TEXT_JUSTIFY_VCENTER);
} else {
dc.drawText(w2, h2, Gfx.FONT_SYSTEM_XTINY, "device not supported", Gfx.TEXT_JUSTIFY_CENTER | Gfx.TEXT_JUSTIFY_VCENTER);
function onHide() {
