Help: Failed invoking <symbol> Invalid Value after last line of active code in onUpdate() runs through
Hey guys,
I am a beginner programmer and am currently struggling with an error which I cant solve cause i don't even know where to start looking.
I have an app called Flightmeter which I am currently trying to improve with new features.
Every since I did this I sometimes get the following error in the sim (the app also hasn't been running on the watch for a longer period of time)
Invalid Value
I put System.println marks everywhere in my code to figure out what causes the problem. usually i would expect it to be some method or class action placed in the onUpdate() part to be the culprit. But my last line in the onUpdate() is a print statement and this I still see in the console. The next line in the console after the print statement is then the error message.
All other code that should be running apart from the on upDate() is just the usual start of most apps codes where you have you sensor and position listeners. Also here I have print statements, but they are not being triggered
Does any one have an idea what can cause this error (it's not memory, i am using around 27000 testing with different watches in the sim - error still occurs.).
All my objects should be dormant after the onUpdate() runs through. Or could it be that some object code is beeing run after my onUpdate() is finished because of some scheduler?
So I am lost. It would be great if anyone had an idea what could cause the problem or at least a way for me to more thoroughly try to pin point the location of where the error is thrown (don't really have experience with debugging apart from using print statements).
Thank you very much in advance for your support :-)
