Two No Brainers - PLEASE ADD
You already pull HR Zones. You are missing POWER Zones. The "pattern" already exists. The system call is essentially identical to HR Zones. It has been asked for for years. Please just add the ability to pull POWER Zones into CIQ.
You already have fillCircle() and drawCircle(). But you only have fillPolygon(). Again, this is a no brainer, simple to add, based on a known pattern. Probably would take someone a few minutes to add. just an oversight I'm sure that it was missing. I work around it by drawing three line segments. But consider adding this as a Class 1 feature request. If Class 1 means it fills an obvious API gap and is extremely easy.
Thanks!
