Failed to connect to the simulator - Out of ideas
So I suddenly seem to be unable to connect to the simulator for some reason...
It does work in safe mode, using a port monitor tool I noticed that in safe mode 2 instances of simulator are started vs 1 in normal mode.
One listeining on port 1234 and one on port 42877, in normal mode only the 42877 instance is running...
What have I done and tried so far:
* Uninstall my antivirus completely
* Disable windows firewall protection
* Different SDK version
* Reinstall eclipse, connectiq and sdks completely
* Remove .m2 and .eclipse folders in the process
* Manually allowed all connections from/to simulator.exe in firewall
* Check if ports are in use by something else (nope)
* Start simulator.exe manually (both as normal user and as admin)
I am running out of ideas, apart from wiping windows and clean install everything... but that's not worth it, in that case connect iq development will be limited to another place
This is on Windows10 x64. latest update, no spaces in path/names of connect iq sdk or projects...
If anyone has any idea! (Perhaps figure out if simulator.exe on 1234 is somehow blocked? Can't find any signs towards that)
