So there is this array I built that i'm stuck with how to display it .
My problem is 2 fold, firstly I am trying to display the entire contents from a single array on the screen in a graphical form.... Y - because the time based Gamin graph in connect is not able to graph anything but time and some variable.
The array is quite big ( 360 objects ) , and I'm not entirely sure, how to write a code that can access each array value, to then put into a code that will complete when it's done the full 360 DC's
I was contemplating doing draw pixel, and basically - each of the 360 values will end up drawing a single pixel.
But how do I make, a looping Dc that will keep looping until it's accessed and drawn all values up ?
The picture I am drawing is a circular graph, so the data format is actually the array index = the angle and the value = the magnitude I am drawing.
Second problem - Draw Pixel requires x and y co-ordinates. would I be better off creating more arrays to store the calculated X and Y values in - to be used in the DC loop, or just adding computations into the DC loop on the fly?
