Parsing a date string to moment
I have a date string on the format "2015-12-28T17:30:00Z". Do I need to parse this string into an options dictionary and use Gregorian.moment (options) to create moment, or is there a simpler way to do this?
    Former Member over 9 years ago
    Ok, thanks.
    It's very strict and handling of timezones makes it a little clunky but it should give you an idea:
    // converts rfc3339 formatted timestamp to Time::Moment (null on error)
    function parseISODate(date) {
    // assert(date instanceOf String)
    // 0123456789012345678901234
    // 2011-10-17T13:00:00-07:00
    // 2011-10-17T16:30:55.000Z
    // 2011-10-17T16:30:55Z
    if (date.length() < 20) {
    return null;
    var moment = Gregorian.moment({
    :year => date.substring( 0, 4).toNumber(),
    :month => date.substring( 5, 7).toNumber(),
    :day => date.substring( 8, 10).toNumber(),
    :hour => date.substring(11, 13).toNumber(),
    :minute => date.substring(14, 16).toNumber(),
    :second => date.substring(17, 19).toNumber()
    var suffix = date.substring(19, date.length());
    // skip over to time zone
    var tz = 0;
    if (suffix.substring(tz, tz + 1).equals(".")) {
    while (tz < suffix.length()) {
    var first = suffix.substring(tz, tz + 1);
    if ("-+Z".find(first) != null) {
    break;
    tz++;
    if (tz >= suffix.length()) {
    // no timezone given
    return null;
    var tzOffset = 0;
    if (!suffix.substring(tz, tz + 1).equals("Z")) {
    // +HH:MM
    if (suffix.length() - tz < 6) {
    return null;
    tzOffset = suffix.substring(tz + 1, tz + 3).toNumber() * Gregorian.SECONDS_PER_HOUR;
    tzOffset += suffix.substring(tz + 4, tz + 6).toNumber() * Gregorian.SECONDS_PER_MINUTE;
    var sign = suffix.substring(tz, tz + 1);
    if (sign.equals("+")) {
    tzOffset = -tzOffset;
    } else if (sign.equals("-") && tzOffset == 0) {
    // -00:00 denotes unknown timezone
    return null;
    return moment.add(new Time.Duration(tzOffset));
    Thanks. Seems like a solid implementation for handling timezones.
