I've almost finished my first Data field, and have hit a snag with the simulator or watch or both.
I used a DC draw variable.format in onupdate(dc) to try and output a 3 digit integer, and for another field, 3 digit float with 1 precision.
In the SIM, I got an error in the dc field, saying found string when expecting float etc... so I moved the formatting into the oncompute section as variable = ( function ).format("%03.1f")
That removed the error, and the simulator works and looks correct.
I then re- sideloaded the app onto my watch, and the fields are not displaying as formatted... they are back to a load of zeros with decimal ?????
Should I be able to format in oncompute when setting a variable function ?
Any ideas?
