I just published my first simple data field into beta and noticed that there is no icon next to my app when modifying app settings in connect iq mobile . How do I set the image I want displayed?
You mean the icon that shows next to your app in GCM in the list of watch faces, widgets, etc? That's the main image for your app in the store. You won't see if for sideloads, and sometimes if GCM is having an issue getting the image from the app store.
No that one showed up ok. The one when you are charging the settings itself. There is a little logo there.
At least with GCM/Andriod I don't see a little icon on the settings screen and never have. I've not tried it, but you can probably add an emoji to the string for a setting and that will show.
Sorry this is what I mean. In my datafields. The logo I uploaded when publishing the app does not show for resistance tracker.
That's the main image for the DFs in the app store. Chart is one of mine and you can look at the app store for it and see the same image:
https://apps.garmin.com/en-US/apps/d741d7b4-8b26-401c-a5bd-0ac91891575d
In Garmin express I noticed everything looks OK . But the mobile app doesn't show the logo. Do you think its because I named the app differently between publishing to the store and what the actual project and file name in Eclipse is called - Exercycle workout vs resistance tracker. Or maybe because i had side loaded originally, removed it and then downloaded via the store??
I think I know the problem - since I have only published as BETA it doesnt show up in connect IQ mobile, therefore logo is not being pulled down. Is there a way to access the developer dashboard via the mobile app and install beta apps?
