CIQ Datafields not displaying power from Tacx Neo
I've been using a number of  CIQ datafields on my Edge 1030 in combination with a PowerTap powermeter & have never had any issues with them displaying the Power readings. I've recently upgraded to a Tacx Neo Trainer, which is paired over ANT+ & am seeing issues with the display of Power on these datafields.
Power measurement on the CIQ datafields works fine when I'm using my PowerTap, However if I'm using my Tacx Neo & receiving power from that I don't get any Power readings on the CIQ datafields. whereas the native Garmin fields display the Power OK. Speed & Cadence from the Neo display just fine on CIQ datafields just not Power. I also tried disabling (though didn't delete) my PowerTap sensor as a test but that didn't change anything. Does anyone have any idea what might be happening here? cheers HD
  • In answer to my own question...
    I paired the Power & Speed/Cadence outputs from the Neo as ANT Sensors on my Edge today leaving the Neo also paired as a trainer & I'm back to getting power reading on CIQ fields again.
    I really didn't think I would have to pair the Neo sensors in both areas to get power readings. I was just expecting that once I paired the trainer sensor then the values from all the associated sensors would display
