I have been working on a program that reads a string and converts it to an array of words. For example, "This is a test sentence" should get converted to ["This", "is", "a", "test", "sentence"].
Because my app has to do this with strings that can contain a large number of words I tried to optimize the program: Instead of using list.add, which is very expensive, to add a word to the array I am using a linked list. For some reason my fenix 3 crashes when the number of words is greater than 37.
This is the minimal code to reproduce the crash:
function makeLinkedList() {
var n = 37; // crash at 37 or more
var start = new LL();
var object = start;
object.content = 0;
for (var i = 1; i < n; i++) {
object.next = new LL();
object = object.next;
object.content = i;
var ret = new [n];
object = start;
// start = null; adding this line prevents crash for some reason
for (var i = 0; i < n; i++) {
ret[i] = object.content;
var n = object.next;
object = n;
return ret;
and this is my LinkedListElement class:
class LL {
var content;
var next;
I have no clue what is the problem, it seems like it has something to do with too many recursive objects. I do not know if this only affects the fenix 3 because everything works well in the simulater.
