Hello,
i am currently struggling with the BLE implementation.
I made an example app similar to Thingy Example but using BLE HR Device instead of thingy and the issue i am facing is that when sensor loses connection and reconnects again (too big distance to device of putting battery out) then the values i retrieve from the data model are freezed.
isConnected() function returns false when switching the device off or going out of range. It reconnects automatically and After switching device on or coming into range then isConnected() returns true again, so it seems to reconnect automatically works generally but not returning any values anymore.
When clearing all objects manually, and choosing device manually again from the beginning it works again.
Is there a workaround or do i miss something?
Same issue appears at the Thingy App Example
Thank you in advance
