Base 64 Encoder (http basic authentication)
I've written a base 64 encoder, which is required for basic http authentication. I thought it might be useful for someone.
class Base64Encoder
hidden static const codes = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/=";
hidden static const ascii = " !\"#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\\]^_`abcdefghijklmnopqrstuvwxyz{|}~";
static function encode(plain) {
var byteArray = toByteArray(plain);
var encoded = "";
var pos;
for (var i = 0; i < byteArray.size(); i += 3) {
pos = byteArray>> 2;
encoded += codes.substring(pos, pos + 1);
pos = (byteArray& 0x03) << 4;
if (i + 1 < byteArray.size()) {
pos += byteArray[i + 1] >> 4;
pos = (byteArray[i + 1] & 0x0F) << 2;
if (i + 2 < byteArray.size()) {
pos += byteArray[i + 2] >> 6;
pos = byteArray[i + 2] & 0x3F;
else {
encoded += "=";
else {
encoded += "==";
return encoded;
hidden static function toByteArray(text) {
var array = new[text.length()];
for (var i = 0; i < text.length(); i++) {
var pos = ascii.find(text.substring(i, i + 1));
if(pos == null) {
throw new UnknownCharException();
array= pos + 32;
return array;
class UnknownCharException extends Toybox.Lang.Exception
var char;
function initialize(char) {
Exception.initialize();
self.char = char;
function getErrorMessage() {
return Lang.format("Char $1$ is not supported", [char]);
[/CODE]
To use with json request, you need to first create a username/password hash:
var passwordString = Lang.format("$1$:$2$", [userName, password]);
passwordHash = Base64Encoder.encode(passwordString);
Then you need to add a headers dictionary to the options dictionary of your json request:
var headers = {"Content-Type" => Comm.REQUEST_CONTENT_TYPE_URL_ENCODED};
if (passwordHash != null) {
headers.put("Authorization", Lang.format("Basic $1$", [passwordHash]));
var options = { :method => Comm.HTTP_REQUEST_METHOD_GET,
:headers => headers};
Comm.makeJsonRequest(url, parameters, options, callback);
Of course you'll need to handle the UnknownCharException (for diacritics and other unsupported chars).
If you find this useful and decide to use it, a pm or reply is appreciated.
    TeunMo thanks! I've used you code - that saved me some coding time. However, it would be better to change ASCII part to UTF8, probably with built-in converter, present in Garmin API (StringUtil class). I'm not complaining, it's just a note to those who will use this code as well :)
