(if the text below is not clear enough please let me know.)
Hello All,
currently i am working on a data field that counts how many times i managed to swum a certain distance.
the counting ellement of the datafield isn't that hard. for now when the datafield starts up it will start counting.
the thing i can not figure out is how to use the pause function of the swimming app. because i whan't to let it count when you stop your timer.
hope someone here has experiance with that.
maybe usefull to mention. i have looked at the sample code "input" but could not figure out if i could use someting from that.
using Toybox.WatchUi;
using Toybox.System;
using Toybox.Time;
class SeriesCounterView extends WatchUi.SimpleDataField {
var counter;
var previousRound;
var timeStrech;
// Constructor
function initialize() {
SimpleDataField.initialize();
label = "Series";
counter = 0;
previousRound = 0;
timeStrech = 0;
// Handle the update event
function compute(info) {
var value_picked = "--";
var thisRound = info.elapsedDistance;
if(counter == 0 && info.elapsedDistance != null){
previousRound = thisRound;
counter = 1;
if(counter != 0 && previousRound == thisRound && info.elapsedDistance != null ){
counter++;
if(counter != 0 && info.elapsedDistance != null && previousRound != thisRound){
counter = 1;
value_picked = counter;
return value_picked;
return previousRound;
return thisRound;
just a little recap for what i need.
if i swim 100m --> couter will set to 1
if i swim another 100m --> counter will set to 2
if i do that another 3x100m--> counter will set to 5
if i swim a different distance for example 200m --> counter will return to 1
