hi,
I just developed my first data field. I started off fairly simple but then did something more advanced, trying to figure out when a new lap had started after a rest period, and displaying multiple stats in a single field. I had some good & bad impressions of the environment, and was wondering what others think.
On the plus side I thought
- it was very easy to get started, with good instructions
- the build process works. Not kidding here, in my current commercial developer role it can take days or more to get a build going.
- parts of the development process work v well, e.g. nice API documentation, simulator with .fit files giving preview, and easy to side-load onto the watch
On the negative side
- it's difficult to figure out where errors occur. You get a message back stating that there's an exception, e.g. symbol is wrong, but you don't even get a line number / a stack backtrace. This seems very basic. I ended up having to add print statements throughout the code to see where it was broken.
- fit file simulation doesn't correspond very closely to what you see on the watch (I was using Vivoactive, maybe this is better for other watches that record second-by-second)
- finally, there just wasn't enough information in the activity.info. As has been mentioned many times before, the lap number is missing together with any data about the lap (I would assume it would make sense to get one info for the overall workout, and another for the current lap). Also a number of metrics are missing that are available in the built-in data fields. For my purpose the number of steps would have been v v helpful (you can back this out from average cadence and time but it's not reliable -- sometimes you see a decrease in steps from one second to the next after a rest period). It feels like custom data fields are very much second-class citizens compared to built-in ones, which is odd compared to APIs I've been using professionally, where company supplied widgets tend to use the same APIs as end-user widgets.
So overall, I was pleased and excited to get as far as I did, and feel the environment has a lot of potential, but without some improvements (especially in terms of the data available) I wouldn't be keen to spend a lot more time on it. Interested to hear what others think. Maybe I've got some of this wrong or there's stuff I ought to be aware of.
