Number.format issue negative numbers
Hi,
I need to convert a number to a hexadecimal format. In my context, it is important that the output string has a defined length. I am facing issues when appyling the conversion to negative numbers. See the code below. As you can see, the length of output #2 and #3 is 8 instead of 4. Any hint would be appreciated.
Thanks, Adam
Code
var x1 = 18, x2 = -18;
System.println(x1.format("%04X"));
System.println(x2.format("%04X"));
System.println(x2.format("%+04X"));
Output
0012
FFFFFFEE
FFFFFFEE
  • In hex, the first bit can indicate the sign, so using a "+" in the format() really doesn't make much sense. The hex value is showing you the "bits".
    Consider "FF".  Based on context, that can be either -1 or 255 depending on if it is considered a signed or unsigned integer when converting to decimal.   There's no "-FF"
    You could do something like an and with 0x80000000 to check the highest bit and do you'r own sign.
    the reason you see 8 "digits" is the last two lines is because a Number in CIQ is actually 32 bits, and since the hightest bit is 1, you see all 8, while in the first line, the highest bit is 0, and the %04x" is used.
  • The documentation for Number.format() says that behaves similar to that available in printf from the C stdio library. This is what happens when you test that code on a C compiler...
    Code:
    #include <stdio.h>
    int main()
        int x1 = 18, x2 = -18;
        printf("%04X\n", x1);
        printf("%04X\n", x2);
        printf("%+04X\n", x2);
    Output:
    0012
    FFFFFFEE
    FFFFFFEE
    You can see for yourself here. You can also take a peek at some pretty good documentation for printf here.
  • If you want to understand why...
    The format specifier %X indicates that you want to display an unsigned hexadecimal integer. There is no such thing as a negative unsigned, no sign would ever be printed. That is why the + flag has no effect. In C/C++, compilers may warn you that the flag is ignored. The GCC C compiler says main.cpp:8:25: warning: '+' flag used with ‘%X’ gnu_printf format [-Wformat=]
    As for why you get the 4 byte values, this is fairly easy to explain as well.
    The negative representation of the positive number N on a 2's complement system is what you get if you flip all the bits in N and add 1. So given the value +18..
    1. 18 is 0x00000012 or 00000000000000000000000000010010.
    2. flip the bits => 0x000000ED or 11111111111111111111111111101101b
    3. add 1 => 0xFFFFFFEE or 11111111111111111111111111101110b
    When you print positive 18 with %04X, you're telling the system to write a minimum of 4 characters, left padding the value with zeroes. So you get 0012. When you print -18, it has the hex value FFFFFFEE, which is larger than the 4 character minimum, so the system displays as many characters as are necessary.
    It isn't clear what you are actually trying to get, but it seems that you want -18 to show up as -0012 (technically I'd hope you'd want to see -0x0012 so that the base is explicit, but whatever). If you want that, you'd have to do something like this..
    function format_signed_hex_value( fmt, value ) {
        var sign;
        if (value < 0) {
            sign = "-";
            value = 0 - value; // positive
        } else {
            sign = "+";
        return Lang.format("$1$$2$", sign, value.format(fmt));
