Usage of nativeNum for a FitContributor
Hello,
What is the purpose for nativeNum when setting up a FitContributor in a (Simple)DataField?
When I first read the doc; ":nativeNum (Toybox::Lang::Number) — If this Field can be treated equivalently to a Field that is included in the FIT SDK use this to indicate the Field Number that is specified by the FIT Profile." I thought it was a way of telling GC/GCM that the field just being created should be treated the same way as another existing field and rendered the same but when reading through the forum and posts about nativeField it sounds more like a way of overriding and existing field.
The reason why I ask is that I have a field that expresses speed in a different way than the standard but problem is that there is no way of telling GC that it is speed and should be rendered as pace. At first I thought that would be easy solved by using nativeNum and the field number for speed...
There are a couple of use cases for displaying pace in a different way, on of the most common is grade adjusted pace.
Best regards,
Tobias
