Extended text description in settings
Hi,
I downloaded an app and realized that one setting in the app (which was adjustable mobile/Express) had an extended description below the title and the current setting. I am wondering how this was achieved?
If I have a look to the programmers guide I can find only those attributes for a property: propertyKey, title, prompt and helpUrl.
I used once helpUrl and indeed it is shown up below the current setting. But I used a real URL. Does this work with text only as well? Prompt seems to be a different feature, at least it sounds differently.
  • I also have added helpUrl parameters to my watch face's settings but the ConnectIQ mobile app just shows the URLs below the setting value. The URL is not clickable.
  • You can use the prompt attribute.
    It is shown (in the ConnectIQ mobile app and in the Garmin Connect mobile app) also for booleans, although the documentation says:
    Some settings will not display a prompt even if it’s provided (for example, readonly or boolean settings displayed as an on/off switch).
  • hi,
    yes i always use "prompt" for textfiled,
    i.e in Garmin connect/IQ is shown like this
    EVENT Time
    use 24hrs format
    <setting propertyKey="@Properties.ET" title="@Strings.EventTTitle" prompt="@Strings.EventTPrompt">
                <settingConfig type="AlphaNumeric" />
            </setting>
