Previous posts suggest that using different resource folders with a different resource string for each of the devices you support for a watch app was the 'best' way of getting the device name at runtime. Is this still the recommended way of doing this?
I am having issues with this because I have not found a way to make this work if you also have different resource folders for different languages because you obviously can't define the resource string in these without getting duplicate definitions of the same string id: one for the device and one for the language. This creates warnings about undefined string resources which I happily ignored until I installed SDK 3.1.x.
At first I had an issue with the SDK Manager which would not let me select 3.1.4 as the Current SDK on top of 3.1.3. Removing the 3.1.4 installation and downloading/installing it again seems to have overcome that issue. However I now cannot run eclipse/simulator in Debug mode. I can run them in non-Debug mode but when I try in Debug mode I just get a blank window and the 'compiler' issues a warning about an undefined string resource for the first of the additional languages, but not the others that I used to see in 3.0.12 (see above) so I suspect that it is barfing over this issue but only in Debug mode (huh?). Of course I tried removing 3.1.4 and using 3.1.3, but the Debug problem lingered, so I am back to 3.0.12 where it all works fine.
BTW I am running eclipse Version: 2019-06 (4.12.0) on a Mac with Mojave (10.14.6)
