One of the news in the newest SDK was this one?
- Add support for showing the current screen position of the cursor in the status bar.
That is something I'm very interested in. How can I activate it? What is that satus bar? Do I need to do something?
You don't have to do anything. In the sim windo, when you move the mouse over the display iof the target device, x=/y= shows on the bottom line of the sim window.
Thanks for yhour answer.
Mmm, that is not my case.
Is there anything else I have to do other than selecting the latest SDK as the one to use? Should I edit any configuration or something on eclipse?
You want to be using the 3.1.4 SDK, and make sure you're using the sim for that. x/y only shows when the mouse is in the display area for the target you're running in the sim.
Well, for sure I'm using the latest SDK:
But the editor seems to be locked on the previous version:
Not sure if I can do something else
Are you launching the sim within eclipse? Close the sim and just run your app. It should launch the sim for you.
Yes, that is exactly how I launch it, and I closed several times. Let me try once more. If it matters, I'm simulating a fenix5
So after a force-quit of the emulator and some problems to make it start again I'm now getting the new features there. Thank you very much.
