Fonts in Resource File using SDK 1.2.1 how do I add fonts?
Hi
Before SDK 1.2.1 I used to load my bitmaps and fonts from the resource.xml file. With a simple line:
<font id="id_font_mex" filename="fonts/mex.fnt" />
Now I'm creating a new watch face based on the Simple with Settings template included in the new SDK 1.2.1 the resource.xml is not there anymore I solved some issues moving some assets to the drawables folder/xml file.
I want to add a new font so I thought that creating a resource.xml will solve the issue but It's not working Eclipse is not reading the file.
Question:
In what file should I add the font I want to use? I'm lost, I did not find anything in the documentation so far.
When using the template with Settings new files are created like: drawables.xml, layout.xml,properties.xml, settings.xml, strings.xml I tried adding the font id in the drawables.xml, layout.xml and resources.xml (created by me)
As always your help is greatly appreciated.
JMX
    The Eclipse plug-in looks for XML files who's base folder starts with "resource". If you want to add a font resource it can be added to any XML file that meets this condition (you could put a font definition in resources/strings/strings.xml). I personally would recommend creating a fonts.xml file at resources/fonts/fonts.xml. You could then include all of the necessary font files within the resources/fonts folder.
    resources
    fonts
    fonts.xml
    mex.fnt
    Hi Ken
    Thank you for your reply. I did try to create a resources.xml file under the resources folder and Eclipse ignore it. I will try your suggestion, I will create a fonts.xml file under the path resources>fonts>fonts.xml
    I will test it once I return from work :)
    Hi Ken
    I just tried your suggestion but is not working, do I'm missing something, the path of the file is resources\fonts\fonts.xml:
    The fonts.xml file only have this info, I tried with and without the <font> </font> brakets
    <resources>
    <font>
    </font>
    </resources>
    The error output is the following:
    Connecting to device...
    Device Version 0.1.0
    Device id 1 name "A garmin device"
    Shell Version 0.1.0
    Could not find symbol id_font_mex.
    Symbol Not Found Error
    in onLayout (C:\Users\Akira\workspace\Mexico\source\MexicoView.mc:25)
    Failed invoking <symbol>
    So I'm still experiencing the same problem, I don't know how to force eclipse to search for the resources.xml or fonts.xml, should be automatic but why is not working? Any ideas?
    Thanks!
  • Are you loading the font with Ui.loadResource(Rez.Fonts.id_font_mex)?
  • Load the font is not working at the moment when the font need more than one PNG file. I thing that is error in SDK 1.2.1
  • <resources>
    </resources>
    In my opinion your file should look like this above. You placed font element into another font element what isn't good idea.
    Are you able to compile your app in the first place?
    <resources>
    <font>
    </font>
    </resources>
    This code implies that you have another folder named fonts alongside your XML file with mex.fnt inside of it. The filename attribute should contain a path to your font file in relation to your XML file. That means you're implying this:
    resources
    fonts
    fonts.xml <-- this file contains filename="fonts/mex.fnt"
    fonts <-- which implies this folder exists
    mex.fnt <-- and this file exists within that folder
