Here's a quick proof of concept.
function onUpdate(dc) {
dc.setColor(Gfx.COLOR_BLUE, Gfx.COLOR_BLACK);
//Draw line
var offset = 70;…
What's the point of a proof of concept without sharing an explanation? Even the gif could be fake.
I can't believe it's a bitmap. One would need millions of them...
I solved similar "graphic problem" two weeks ago - I wanted to design an analog watchface similar to Garmin factory default at Fenix 5 Plus but with some added features. After a huge analysis of watchface screencopies I concluded that the Garmin factory watchfaces (analog, at least) are not standard CIQ virtual machine applications. May be, they have CIQ extended by some specialized graphic functions not accessible in public SDK or the watchfaces (or their parts at least) are written directly in the ARM C/assembly language to decrease battery draining AMAP and enable the exceptional watchface design.
Thus, in CIQ VM, you have two variants how to place a text in circular shape:
1. Use predefined arrays with character patterns, perform a rotate & shift transformation and call putPixel to set pixel in display memory buffer.
2. Use font (or bitmap, but it is more memory consuming) resources with several typefaces for one character.
The first one is very slow, but could be effective if you have only several small and time-to-time changing characters on the screen. The second one is faster but memory consuming. It can be effective when you need to change the numbers only in second-to-second ratio. Of course, it is possible to use several tricks, for example if the word STEPS has five different positions according to the number of displayed digits, you can define five bitmaps with the whole word STEPS and use the right one.
Will you publish the code for this?
It would be great if Garmin provided an API for it. While it's clearly possible with the existing APIs, having an API in the SDK would make it much easier, and it would allow Garmin to optimize it to ensure it provides the best battery life.
Wow, this looks amazing. Wow. Wow, At first, I am lost for words.
Thinking about this could be done (and I don't mean this animation, this is Franco's special topic) a first idea could be:
What do you think? Franco, it would be great if you could share some principles how you setup this. You wrote "a quick proof of concept". If this would be really possible in a quick way which can be shared among the community this could end up with really cool upcoming watchfaces/apps in the store.
