Brandon.ConnectIQ no it's not working correctly. Still getting this bug in the simulator.
And because I didn't know it can return [180, 180] even with QUALITY_POOR, it prevented a location to be acquired by user this weekend and I have to do another fix of Garmin developer's QUALITY_POOR work.
What's happening is that's what you see when playing back a fit file in the sim where GPS was lost (in a tunnel for example). With the sim, the quality doesn't change in that case. I first saw this years ago when playing back a fit from someone who had gone through a tunnel, and I have code in the app for just such a case with the sim. This only happens in the sim, not on a real device, as there the quality does change.
OK, I know it's been a while, but it's still an issue. When you feed this bogus 180/180 location in something like this:
l
var myLocation = new Position.Location({:latitude=>myloc[0], :longitude=>myloc[1], :format=>:degrees});
var myMoment = new Time.Moment(someUnixTime);
var myLocal = Gregorian.localMoment(myLocation, myMoment);
timeOffsetDays = myLocal.getOffset().toDouble() / 86400.0d;
it blows up with an uncatchable "unexpected type" exception. The only way around this is to put in code to catch and replace the bogus location with some default before you let it go downstream. It seems like the location should be null instead so the usual test for it can work as designed. As this is now a second test is needed to validate the location.
